09-01-2022 07:58 AM
Solved! Go to Solution.
09-25-2022 10:30 PM
ehunt22Way overkill, but works I guess.https://zentalk.asus.com/en/discussion/comment/229615#Comment_229615
I have a cable creation usb c to hdmi Cable
No other hubs used
Forum not allowing to post a link do here is an image with some basic specs
09-27-2022 08:13 AM
Danishblunt😂😂🤣🤣😂🤣😂🤣🤣😅🤣🤣🤣😀😁https://zentalk.asus.com/en/discussion/comment/229615#Comment_229615
How exacly do you expect him to use a DP connector in an HDMI port?
09-27-2022 09:58 AM
ehunt22Wtf but still 60hz not even 120hz did you tried on 720p there so apps that change resolution and dpihttps://zentalk.asus.com/en/discussion/comment/229615#Comment_229615
No other hubs used
09-27-2022 01:28 PM
zxops47Makes no difference. WIthout custom kernel it's not possible to do 120hz.https://zentalk.asus.com/en/discussion/comment/229785#Comment_229785
09-27-2022 07:34 PM
zxops47https://zentalk.asus.com/en/discussion/comment/229785#Comment_229785
zxops47Try this work but no charging USB C to DisplayPort Adapter 8K@60Hz/4K@144Hz, CableCreation USB Type C to DP 1.4 Cable Adapter
Or you tell me name of your cable or usb hub you used. Did it USB 3.1 Gen 2 supports speeds of up to 10Gbit/s if your device is rooted try to change resolution of the app/game to 720p then try above 60hz
zxops47That's 4k60Hz, at lower resolutions like 2k or 1080p the specifications of the cable say that it can support 120/144hzhttps://zentalk.asus.com/en/discussion/comment/229785#Comment_229785
