06-23-2021 11:24 PM
06-25-2021 10:55 AM
soham1995No , factory reset is essential to completely fix itMight be the back glass for the air triggeers , did drop the phone once or twice but with a case on .won't be able to factory reset my phone, as I have alot of data stored . Would it be possible to fix the multitasking issue with the next software update ?
06-25-2021 10:21 PM
SaifuddinYes you're absolutely right about the air trigger issue . When I tap/press my fingers into my phone in the centre at the back glass. The triggers activate .There is some kind of software issue in your device , make sure its on latest version and perform factory reset and that will probably fix multitasking issue
For air triggers, if factory reset wont fix it than your back glass is causing issue , go to service centre they will replace the back glass if thats the cause
https://www.asus.com/in/support/service-center/india
You can find service centre here in India
