Problem with overlapping audio
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-07-2021 06:16 AM
Model Name: ROG Phone 3
Firmware Version: 18.0410.2104.124
Rooted or not: No
Frequency of Occurrence: Every time I exist any video file midway
APP Name & APP Version (If your issue relates to the app): Any 3rd party app which plays a video, that includes ads.
The problem is every time I exist any video file midway it continues to play in the background even if I switch of the screen and it stops only after the whole clip has played. And nothing I do has any effect on the audio, it just keeps playing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-07-2021 06:23 AM
anand.gautamCheck after you restart your device once first.Please tell us some basic information before asking for help:
- Model Name: ROG Phone 3
- Firmware Version: 18.0410.2104.124
- Rooted or not: No
- Frequency of Occurrence: Every time I exist any video file midway
- APP Name & APP Version (If your issue relates to the app): Any 3rd party app which plays a video, that includes ads.
Then Just try to clear cache and storage of Asus launcher and check again
Settings > apps & notifications > see all apps > Asus Launcher > storage > clear cache/ storage/ force stop. Now you can check again.
Also you can check this issue in safe mode for confirmation.
Press and hold power key for few seconds you will see option to shut down, restart etc. Just tap and hold on shut down for few seconds system will ask you to entre safe mode. See if problem is same there.
To exit safe mode just restart your device.
Please try to specify names of those apps where you are seeing this issue. And i recommend you to trun off display over other apps for that particular apps in which you are facing issue.
What happens when you clear all apps from recent tab? Does it still keep playing in background??
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-07-2021 07:41 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-08-2021 02:18 AM
The problem was still there even after closing all the recent apps but I used the above method by @AmitGarde and it helped, thank you so much Amit 😊
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-08-2021 03:44 AM
anand.gautamI am Glad that i was able to help you 🙂Hey @ARP_ASUS
Cheers.
Happy Gaming! Stay safe.
