Problem with overlapping audio
anand.gautamanand.gautam Level 1
edited July 2021 in ROG Phone 3
  1. Model Name: ROG Phone 3
  2. Firmware Version: 18.0410.2104.124
  3. Rooted or not: No
  4. Frequency of Occurrence: Every time I exist any video file midway
  5. APP Name & APP Version (If your issue relates to the app): Any 3rd party app which plays a video, that includes ads.
The problem is every time I exist any video file midway it continues to play in the background even if I switch of the screen and it stops only after the whole clip has played. And nothing I do has any effect on the audio, it just keeps playing.
Comments
  • Check after you restart your device once first.
    Then Just try to clear cache and storage of Asus launcher and check again
    Settings > apps & notifications > see all apps > Asus Launcher > storage > clear cache/ storage/ force stop. Now you can check again.
    Also you can check this issue in safe mode for confirmation.
    Press and hold power key for few seconds you will see option to shut down, restart etc. Just tap and hold on shut down for few seconds system will ask you to entre safe mode. See if problem is same there.
    To exit safe mode just restart your device.
    Please try to specify names of those apps where you are seeing this issue. And i recommend you to trun off display over other apps for that particular apps in which you are facing issue.
    What happens when you clear all apps from recent tab? Does it still keep playing in background??
    Thanks!
  • Hi anand.gautam,
    Have you tried the above steps mentioned?
  • Hey @ARP_ASUS
    The problem was still there even after closing all the recent apps but I used the above method by @AmitGarde and it helped, thank you so much Amit 😊
  • I am Glad that i was able to help you :)
    Cheers.
    Happy Gaming! Stay safe.
