08-25-2021 09:50 PM - last edited on 01-16-2024 01:34 AM by ZenBot
09-03-2021 10:26 AM
PervageCEO will not be able to help you with anything, they are absolutely clueless about technical stuff.I agree @Megalox . But devs are not responding. Maybe we should send CEO Feedback so that it can be escalated.
09-03-2021 11:22 AM
09-03-2021 11:35 AM
PervageWell I take it then something went wrong while flashing, since there are no reports from many users. I guess only solution is a raw flash.@Danishblunt Screen Flickering issue is because last update was fixed for Proximity Sensor. Asus devs touch the wrong code for P-Sensors 😄.
Danish Bro I have reset my device 2 times and it is not the solution brother. After every update we have to reset the device? Thats not acceptable.
09-03-2021 01:04 PM
09-03-2021 08:12 PM
Megalox@Danishblunt The issue is with video playing on browser and many users don't use browser for play videos that might be a reason that not many user have reported it.As mentioned, I've started my sentence stating that I did the upgrade with factory reset. In addition to that, this issue is happening to other users as reported here https://zentalk.asus.com/en/discussion/52394/netflix-flickering#latest which is a similar behaviour. I haven't got Netflix, but it happens to me with the browser.
To test it, set the refresh rate to 90hz or above, open a browser and play video using Facebook, Vimeo, Youtube, etc.
I've tested with other browsers as well to rule out Chrome.
The issue doesn't happen using 60hz refresh rate.
Issue doesn't happen when playing a video using, for example, youtube app, insta, gallery or FB apps themselves.
Chur
