Info about max temperature
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-11-2020 01:37 AM
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
What is the maximum temperature to not exceed in order to not damage the phone components while playing games?
I usually stay on an average of 41/40 degrees while playing Pubg...it will damage the phone if the temperature is this for about 2/3 hours?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-11-2020 03:11 AM
david84rmSince the heat leaves the phone you'll be fine,I played 5 hours on overclocked performance and on 51 degrees,it will not damage your phone or your battery,if your charge it tho,then the battery will have a bit of a problem in the long run so focus on the way you are charging instead of the temperature of the phonePlease tell us some basic information before asking for help:
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Btw I play 90 FPS ultra HD with water reflections on 47 and there is no throttling so it's fine
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-11-2020 03:18 AM
GREEKLEADERNo offense but i smell BS on your statement. There is no 90 fps option on ultra HD, especially with water reflections enabled.https://zentalk.asus.com/en/discussion/39954/info-about-max-temperature
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-11-2020 03:29 AM
CravenMaybe he is using 3rd part software to enable ithttps://zentalk.asus.com/en/discussion/comment/132160#Comment_132160
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-11-2020 03:29 AM
GREEKLEADEROk Thankshttps://zentalk.asus.com/en/discussion/39954/info-about-max-temperature
