Double Tap to Wake not working
Saif_Munshi
ROG Phone 3
Firmware Version - i could not find
not rooted
Frequency of Occurrence: Every time
I am using ROG phone 3 just received a brand new phone yesterday and i am facing the same problem as mentioned above. Double tap to screen off is working properly but Double tap to screen on and Swipe up to wake up is not working at all.
is this because of my Tampered glass? Or there is a problem with my Phone.
Gestures on Dark screen like W,S,Z to launch different apps are also not working. Inshort once the phone is locked/in idle mode none of the gestures work. Except 'lift to check phone'
is there something i am missing out or doing wrong. Please need help with this issue ASAP
15 REPLIES 15
Gustav_ASUS
Community Legend III
// Discussion thread moved to the correct section.
ARP_ASUS
Community Legend II
Hi @Saif Munshi,
Share this:
Firmware:
Go to setting => About => Software information.
Share a video once you have enabled the same so that we can see if you are following it correctly.
sumitdeb
i am facing the same issue. Double tap to wake is not working. Firmware - Version WW-17.0823.2007.58
I do not have any tempered glass on the phone.
Double tap to sleep is working fine
sumitdeb
ARP_ASUS
Hi @Saif Munshi,
Share this:
Firmware:
hey ARP_ASUS, this seems to be a Software issue.
double tap to sleep is working
Tilt to wake is working
However double tap to wake is not working.
The option is enabled in Gesture settings.
please help us escalate this issue. This is a basic feature.
sumitdeb
hello. How do we file a bug for this and escalate the issue to Asus ? Any moderator here?
