Can we activate second LED flash light in Rog 3??
jerquait
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
20 REPLIES 20
ARP_ASUS
Hi jerquait,
You can't activate second LED flash light, it is for the accessory. Thanks.
markovo
Rising Star I
The screen is too big for it's resolution thus the sharpness is bad.
Saifuddin
Zen Master III
markovo
R u serious , i mean i have a 32inch tv with 720p screen idk why i assumed thats its 1080p before buying and come to know its 720p but bought it 4 years ago so i was dumb then but my point is this is not what you call large and screen dont losse any detail at this size, its the calibration that sucks and screen will loose quality at high refresh rates coz thats how oled works
markovo
Rising Star I
Saifuddin
https://zentalk.asus.com/en/discussion/comment/166612#Comment_166612
And the image is razor sharp right? No it is not. You can't compare a tv screen of any kind with a phone screen or even a monitor as tv pixels are way bigger and you watch it from greater distance. But if you are satisfied with 720p ot a 32" tv than 1080p on phone will be a magic to your eyes. Comming from a 2K phone screen with more than 500 ppi, ROG 3 screen is not sharp enough for me. Calibration does not have anything to do with image sharpness.
Saifuddin
Zen Master III
markovo
https://zentalk.asus.com/en/discussion/comment/166769#Comment_166769
Well , if you compare a 2k panel with fhd panel then i dont think its a rocket science to understand that its logical to have less ppi and that means less sharpness 🤷‍♂️🤦‍♂️
And theres no land and sky difference of 2k and fhd in mobiles panels as the panels size small , and i also came from a 2k panel to fhd so its something you wont notice afte few hours of using the device
