Blinking red light after battery die at 0%
Edmund_CPN
Model Name: ROG Phone 3 Strix
Firmware Version: 17.0823.2012.122
Rooted or not: Not Rooted
Frequency of Occurrence: First time
I saw some post about rog phone battery die at 0% will cause the phone not about to boot up after plug in the charger and the phone will blink red light repeatedly. So I want to test my ROG Phone 3 and I let the battery die at 0%, then I plug in the charger but my phone is not boot to the charging screen, my rog phone 3 just keep blink red light around 10min. After 10min only able to boot to the charging screen.
I hope everyone who saw this post do this test on your phone and post your result here.
For ASUS, I hope you give a very good explanation about this issue, because I saw you just ignore the user who have this issue. This issue clearly is not normal, please reply ASAP.
35 REPLIES 35
gugul
Rising Star II
Edmund CPN
  1. Model Name: ROG Phone 3 Strix
  2. Firmware Version: 17.0823.2012.122
  3. Rooted or not: Not Rooted
  4. Frequency of Occurrence: First time
Man that's not even an issue. It takes some time for the battery to reach a minimum potential where it could power the display. It's like written in manual of every device. It is always recommend not to let the battery die deliberately. Don't go lower than 5%. It's harmful for the battery. And talking about the red light blinking, it means the device is working and the battery is getting charged. It'll be a Matter of worry, if it doesn't start blinking. So, just chill out mate.
Edmund_CPN
gugul
https://zentalk.asus.com/en/discussion/42429/blinking-red-light-after-battery-die-at-0
laxmikarnaidu
  1. Model Name: Asus Rog Phone 3
  2. Firmware Version: 17.0823.2008.70
  4. Frequency of Occurrence: 1
My ROG 3 phone battery died and was not starting upon connecting the charger...Just wierd red lighy blinking,...waited for 1 hour to startup while on charging and finally the phone got started
Did anyone face this issue in ROG 3 phone. ?
Asus Rog Phone 3's battery died..won't startup...red light bliking
First of all, you are not the ASUS staff and that's just your opinion. I know need take some time to power the display, but it does not take around 10 min to power on the screen and see it is charging and the battery is 0%. When battery die, normally you just plug in the charger, and the phone will immediately boot to the charging screen and it will show "charging at 0%". I don't know how many phone you use before, but every phone I use all work like this. If you telling me it is normal to wait 10min to see the screen when my phone battery die, ASUS has some serious problem when develop this phone.
By the way, please click the link and see the other guy with the same issue. Please do let me know many phone do you used before and what phone are you using right now.
Edmund_CPN
@Anders_ASUS @Titan_ASUS @Laura_ASUS @Kris_ASUS
Please help clarify this issue, I would be very appreciated.
gugul
Rising Star II
Edmund CPN
https://zentalk.asus.com/en/discussion/comment/142954#Comment_142954
https://zentalk.asus.com/en/discussion/36363/asus-rog-phone-3s-battery-died-wont-startup-red-light-b...
I'm not an Asus staff for sure. But as I have the device currently in use, I just thought that I was eligible to answer this thing. Well This is my 10th device and if I talk about facing this thing in my previous devices, let me just tell you, I don't take my device that low. But a couple of times I had to and 7 out of 9 devices booted up after 5min. So I think that's a pretty normal behaviour.
The post of the other guy was serious because in his case it booted up after 1 hour. So there's a difference in between one hour and 10mins.
You need to check the frequency of occurrence too. A one time occurence doesn't make it a bug or a problem. Repeated occurence does.
Anyways If it bothers you then definitely it's an issue for you and I hope mods will clarify this ASAP.
