09-09-2020 01:18 PM
09-16-2020 05:21 AM
dolevnadav1992Yes from 90% to 20% I get 6-7 hours of sot on an avghttps://zentalk.asus.com/en/discussion/comment/111251#Comment_111251
6-7 screen hours?
09-17-2020 12:41 AM
09-17-2020 02:15 AM
09-18-2020 02:04 AM
dolevnadav1992If you get 4-5 hours from 80%, then you would normally have 40% battery left which isn't that bad. Some apps you find as simple apps might use more power than you think. Generally apps with a constant stream like youtube or netflix use much less power than you would think because the CPU has been optimized for this kind of apps.Please tell us some basic information before asking for help:
- Model Name: Rog phone 3
- Firmware Version:58
- Rooted or not:
- Frequency of Occurrenc
- APP Name & APP Version (If your issue relates to the app):
Hey guys My device is 10 days old
And I feel like my battery is running out very fast
I charge the device up to 80 percent I end the day with about 20 percent
But I'm not playing at all And I'm not too much in front of the screen either Maybe 4 5 hours on average
Please can someone tell me how long its battery lasts and how can I tell if it is a faulty battery?
Or did she fix and everything's fine?
Battery life 😔
09-18-2020 09:11 PM
MV@MV @Anders_ASUS Look at the Android system usage. It takes more than 30% if we use Netflix app. Due to the massive 6000mah battery we get good SOT and thus this problem is ignored. I have already reported this in another post. This issue started after .58 update. If Asus can fix this bug users will get another 1 or 2 hours of SOT.Pretty top notch battery life. 100 -9%
