Battery draining
jptripathy576
Hello ever since the recent update my Rog phone 3's standby battery drain has increased infact overnight it fell down from 95 to 75 and in about 2 hours 3 percent went down and I hadn't used it yet. So please solve this issue via some software update
4 REPLIES 4
g4m3raddict
After the latest updates battery really is draining fast. Something should be done to take care of this drain.
ARP_ASUS
When you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
rajpc381
ARP_ASUS
Its was awful in the last update, but this one takes it to whole another level....its doesn't even feel like 6000 mah
as19103
Rising Star I
idle drain has increased. seems like device is not going in deep sleep.
