09-10-2020 09:03 PM
09-11-2020 10:35 AM
09-14-2020 08:39 AM
09-15-2020 11:34 PM
ARP_ASUSHi,
When you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Also, if not already updated make sure your phone is on .58
