Battery drainage issue after Android 12 update
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-21-2022 03:19 AM
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Is anyone facing battery drainage issue after update to Android 12. Because battery drains faster for me after update it was not that case with Android 11. Please let me know anyone with similar issue and any solution worked for them
Model Name:
Firmware Version:
Rooted or not:
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2022 08:12 AM
Hi mentos_dbz,
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Please also refer to the below article, after so many charge/discharge cycles the battery life will surely diminish.
https://www.asus.com/in/support/article/604/
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-25-2022 04:05 AM
