Battery drain
jptripathy576
My phone's battery came down to 90 with just 15 mins of screen on time
7 REPLIES 7
BPM
Rising Star II
Saifuddin
https://zentalk.asus.com/en/discussion/comment/209735#Comment_209735
As i have Stated before, its software causing drain to you guys and i Suggest factory reset ,
I did battery drain test before on idle with wifi and my device lasted over 15 days or something
And my battery condition is probably worse than you guys so you can get an idea what's going on here.
I did test on A11 only.
A factory reset is a hell of a hassle to go through... I'll try that over this weekend and see if it helps any...
Also, 15 days? Are you not using your phone for anything? 🤔
Saifuddin
Zen Master III
BPM
https://zentalk.asus.com/en/discussion/comment/209884#Comment_209884
I didn't use it at all for that period of time to test idle drain.
kompellavedanth
Rising Star I
I already did factory reset but the issue still persists so I gave up.
