09-29-2020 08:46 AM
10-07-2020 07:10 AM
10-07-2020 09:07 AM
achalxaxa60You mean deleting everything on phone and doing? Too much work 😅Hey everyone if you have battery drain problem then try to factory reset your phone and restart it .i know it's very hard for some people but if you do this then your phone will drain like 5% in more then 1 hour on normal use like surfing YouTube i tried and it worked in 2008.78 update. It will drain your battery as new .If it works PLZZ give a like.
THANK YOU
10-07-2020 07:30 PM
10-07-2020 09:47 PM
10-07-2020 10:27 PM
joshua.aquino18dIs it normal for 6000 mAh? I got better results on p30 pro with 4200 mAh.Canni check you battery usage
