BATTERY DRAIN FAST .78 UPDATE ROG PHONE 3
devicentextian
Rising Star II
Model Name:ZS661KS
Firmware Version:.78
Rooted or not:not
Frequency of Occurrence:
128 REPLIES 128
barillanr1
I would recommend everyone with battery drain problems, to download gsam battery app. It gives a better understanding what the phone is doing and how much it's draining.
devicentextian
Rising Star II
lilnotoriouz
fully charged my batt and after fews minutes it starts draining...
turn off your phone so it won't drain lol
devicentextian
Rising Star II
barillanr1
Most apps like that are filled with virus i would recommend use the system built-in to check battery status than downloading 3rd party apps
When I don't play games also battery is draining to fast can you solve my problem? Please
arry_nyp
Hi ROG Phone 3 users.
I did purchase a new ROG Phone 3 from ASUS Exclusive Store at Bugis on September 2020.
I am aware that the phone has a very large battery capacity, 6000 mAh.
I have been observing the battery life of the phone and noted the battery life’s performance has been performing poorer than expected.
So, when I did fully charged the phone at 100%, I set the phone to Airplane Mode and leave it as it is for about 7 days. After 7 days I noted the phone’s battery percentage remaining is only between 30% - 40%.
I compared with another new phone I have, Samsung Galaxy S10 Plus. The phone’s battery capacity is definitely lower than the the battery capacity for ROG Phone 3. However, when fully charged and kept in airplane mode for 7 days, the battery percentage remaining is much higher at more than 80%.
So, is there an issue with the battery performance of the ROG Phone 3 please?
Please do advise. Thank you.
