Android 11 finally finished
Danishblunt
Hall of Fame I
https://rog.asus.com/us/phones/rog-phone-3-model/helpdesk_bios
Taiwan version is released, now we just need to wait a couple of hours for the WW version.
#Hype
28 REPLIES 28
Saifuddin
Zen Master III
CHOOZR
the update seem to be for Taiwan only.
https://rog.asus.com/tw/phones/rog-phone-3-model/helpdesk_download
ZS661KS software Image:WW-18.0410.2105.133, 此軟體僅提供給TW 版本的客戶更新使用.
this translate simply to TW user
Its for Taiwan as it is mentioned but also ww is also mentioned in software version which creates a confusion but then i flashed it and everything works perfectly, even volte is working which makes me think its global version only
My Vodafone and jio volte (India) are pretty stable
On A10 Vodafone volte was not stable but it is now
himverma2012
Rising Star II
Beta users were already on the same .133 version for quite some time. It's a WW version only. Shouldn't be a problem. But yeah, I hope you can see that it doesn't have display fix. Also, BGMI lags a little while in lobby (could be BGMI's issue). Other than that, it's stable to be used as a daily driver.
dangeorge1uk
Hi guys
I have the version QKQ1.200419.002.WW_Phone-17.0822.2005.11
Am I correct to assume that this will be fine to download the firmware as it has the WW part in the build number?
Thanks in advance for any advice, I'm based in the UK so I had this shipped to be with a globally flashed rom previously from China I believe for the global use.
Danishblunt
Hall of Fame I
dangeorge1uk
Hi guys
I am not sure how it will act on an old firmware like you have, I do remember them doing some preparations in order to be able to upgrade to A11 in the 143 version.
dangeorge1uk
Danishblunt
https://zentalk.asus.com/en/discussion/comment/177525#Comment_177525
Thanks for the response, I think I'll just stay clear for now and keep an eye out on any further info 🙂
