System: Mesh
Battery or AC: AC
Model: ZenWifi AX
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
Hi, I plan to set up a ZenWifi AX mesh configuration with host and one node. I could easily use a wired backhaul connection because there is already a CAT7 cable between the planned locations. But in this cable connection there is switch interconnected, where I also hook up other devices.
Will this be a problem?
Or does the backhaul require a uninterrupted straight cable from host to node?
Would be good to know, before I start with the setup.
Thanks!
