Node Connection Issues / Registering issues for ZenWifi AX 2 node system
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-20-2021 05:15 AM
System: ZenWifi XT8 (AX6600 Tri Band WiFi Router)
Battery or AC: AC
Model: XT8
Frequency of occurrence: 100% of the time
Reset OS: Yes
Screenshot or video:
Detailed description:
2 issues - 1st, I cannot register my product online. I get "Invalid SN". I have tried both nodes that came in the box, but get the same on both.
My S/N's are:
Primary Node: L7IAHZ009197
Secondary Node: L7IAHZ009198
2nd - Out of the 2 nodes I have received, only one works correctly 100% of the time. The second node drops connection after about 15 minutes. It requires rebooting the node manually to restore the service, but still will drop connections and go offline.
I moved the 2nd node to 3 feet / 1 meter from the primary. Same issues. After approx 15 minutes, it drops to blinking blue LED.
The firmware on both nodes are identical and up to date as of 4/19/2021.
I removed the node, performed a factory reset, and attempted to reconnect the node, but it is failing to connect.
This problem has been on-going since January, 2021. I haven't had the 2nd node stay connected for some time. I have tried resetting, checking firmware, etc. And it will not stay connected.
Battery or AC: AC
Model: XT8
Reset OS: Yes
My S/N's are:
0 REPLIES 0
