Mouse does not work with TUF A15
Tufa15
System: TUF A15
Battery or AC: Not Applicale
Model: FA506IH
Frequency of occurrence: Always
Reset OS: No
Screenshot or video: No
Detailed description:
I have a mouse that works with all of my laptops but the Tuf a15. The mouse is okay, it works in other computers. The laptop’s USBs (one 2.0 and two 3.0) are also okay, other mice and pen drives work as expected. Whenever I plug in the mouse, a notification “your USB device malfunctioned” comes up. In device manager it shows “device descriptor failed” when plugged into the 2.0 port and “set address failed” when connected to the 3.0 port.
The mouse works if I connect it to the laptop via an unpowered USB hub.
Strangely the mouse lights up for a few seconds and then powers off as soon as the notification on the laptop comes up.
I did a few tests and am 100% sure it is a software/BIOS issue.
I am on BIOS 309
7 REPLIES 7
Blake_ASUS
Community Legend II
Then what kind of mouse is it? which brand a model?
So all other external device work with the A15 directly expect this mouse?
Tufa15
It is a "gaming" mouse with RGB and 5 buttons (does that help?). It's a little domestic company.
Yes all devices work directly. I have reason to believe that hardware is not the problem, but the software/BIOS. Also I updated to 311 and still doesn't work.
Blake_ASUS
Community Legend II
Are you able to share a link of that mouse?
If only 1 device is not working well....it's very likely compatibility issue.
But we would need more information to find out.
Tufa15
https://www.amazon. in/Live-Tech-Advance-Programmable-Desktop/dp/B07DWWJ72T
Sorry for the late reply. I can’t post links with this new acc. So there is a space between “Amazon.” and “in”
I think it’s a compatibility issue too. Can it be fixed by you guys without having physical access to the mouse?
