Issue related to Hight CPU Temps while gaming.
SamerLOL
System: Windows 10 Home
Model: Rog Strix G713QM
Frequency of occurrence: Constant
Reset OS: No
Screenshot or video: yes
Battery or AC: ACS
System: Windows 10 HomeSHello,
I bought my new gaming laptop for the first time, and it has been 12 days since the day I bought it.
The problem is how do I know if the temp of my CPU or GPU is in the normal range while idle or gaming.
for example. when I play Battlefield V the CPU temp up t 93-94 Celsus. while GPU stays in the 60s.
is the temp for the CPU will hurt the CPU or the components in the laptop?
I know the max temp for my CPU is 105 Celsus, based on the AMD website. but in the long term, it will affect my laptop? since the laptop is new, there is no issue with the fans such as dust.
Laptop Specs:
CPU: AMD Ryzen 9 5900HX
GPU: NVIDIA RTX 3060 6GB.
8 REPLIES 8
Blake_ASUS
Community Legend II
SamerLOL
https://zentalk.asus.com/en/discussion/comment/178346#Comment_178346
Yes, On the first day. I updated the BIOS.
As I told you On turbo mode reaches 97-98 Celsus. but on Performance 94 Celsus.
Yes, I mean all the time at 97 98 during turbo mode? or just a while? or just one time when playing?
Also, does it only happen with battlefield V?
SamerLOL
Blake_ASUS
https://zentalk.asus.com/en/discussion/comment/178690#Comment_178690
Yes, All the time, while playing battlefield.
I never tried it on other games.
I will try and tell you back.
g_nitin1007
hey there ping me I can help you to get it down in between 70-80 degrees for cpu
foxontherun61
Hi
I don't know what temp it is running at and I don't know how to find out. It is very hot and the fan is running hard. Im only playing fortnite. Can you please help with how to see the temp and how to get it down.
Thanks
