Others
Forum Posts
Speakers
My phones speaker is not working and the Bluetooth is disabled. There is also something called Qualcomm that's disconnected but won't connect which I believe is associated to the functionality of the sound . Kindly assist
Owako by Star I
  • 56 Views
  • 1 replies
  • 0 kudos
Keyboard
setting my new asus notebook. It seems my keyboard is locked, I am not getting any response from it. What can I do?
Tangi by Star I
  • 90 Views
  • 1 replies
  • 0 kudos
overlay
why when I press m3 or m4 the screen does not show that the configuration has changed or that the microphone is turned on? I reinstalled Windows and after that such a problem appeared. im on old wersion (5.9.9.0) after updating it problem does not di...
Secure Boot Cannot Be Turned On
I've already trying all of method that suggested by the internet. But my BIOS still doesn't letting me to turn on the Secure Boot. Is there any method to solve this? (My device is: ASUS TUF A15 with series FA506IV) #SecureBoot #ASUSTUFThank you.
product already registered
hello please help mei just bought a 2nd hand laptop ang i cant register it to my acc, is there any solution?
Resolved! Battery Charging Limiter on ASUS TUF
Hi,I have problem with my ASUS TUF FA507UI that I recently buy.I use Unix (Ubuntu 22.04 LTS) on my device to run heavy GPU workloads, which is why I installed it in the first place. For the GPU to run properly on my laptop, it needs to be plugged in ...
