08-05-2019 09:00 AM
08-06-2019 07:14 PM
08-09-2019 06:36 PM
08-10-2019 03:31 AM
dangkang.m posted on 2019/8/10 01:36 The same problem qith me, While starting a notive appeared "Android is starring" Optimizing app 1 of ...Many asus apps has been discontinued and not icluded in Marshmallow upgrade. Factory reset and wipe cache partition in recovery mode should resolve the issue with optimizing apps. Just to note you will loose some apps. Check your mobile banking app for if it has all of its permitions................
08-10-2019 07:00 AM
