2 hours ago
I have an Asus AX600Tri Band Wifi Model XT8 router system. When my system goes down or acts up, I unplug everything from the model on out, then after a few minutes plug everything back in sequentially. Usually this works, but not this time. On my most remote unit (I am not sure what to call it) the light starts out flashing green, then goes to red. I have tried several times to reset things, but without success.
What is likely the problem? How should I fix this problem
S/N L4IAHZ001884
Please help.
