ASUS TUF F15 FAN PROBLEM
HARI_KRISHNA
System: ASUS TUF F15
Battery or AC: BATTERY AND AC
Model: TUF F15
Frequency of occurrence: FREQUENT
Detailed description:During Initial bootup of the system the fans are running with sufficient RPM but after logging in, the speed is gradually reducing and at some point of time its showing 0 RPM and the fans are also not rotating. I don't understand why this is happening , there are no physical damages and all the softwares (MY ASUS , Armoury Crate ) are up to date.
Please suggest me the appropriate solutions for this problem......
Blake_ASUS
Community Legend II
Hi there,
Can I have the accurate model name? FX506IU?FX506QM?
And your BIOS and OS version are?
May I know if the issue happen after certain update? like after Armoury Crate 5.0 update?
HARI_KRISHNA
Blake_ASUS
Hi there,
Model is FX506HCB
I updated my BIOS just before posting my first post..
Blake_ASUS
Community Legend II
Hi there,
So...can I have the BIOS version?
And please enter BIOS to load default setting again.
