Asus Fx516 3060 Screen warm color problem
faraj_pro
i bought Fx516 3060 laptop. color of this laptop is very warm and it can't see white color correctly.
ScreenShot:
i try to change RGB color and add some blue but it still warm. i change any setting like color management
in windows, graphic command center,ArmouryCrate and etc.
even in boot menu color is too warm. i saw this (https://zentalk.asus.com/en/discussion/47892/asus-tuf-dash-f15-screen-color-too-warm) but his problem was not solved
what should i do?
4 REPLIES 4
Blake_ASUS
Community Legend II
Hi there,
It is not a problem.
Please kindly understand that FX516 series is using IPS panel.
It is normal that IPS panel is showing much warmer color than other kind.
Thank you very much.
faraj_pro
The laptop on the left also has an IPS screen. I checked many laptops with IPS panel. None of them were warm and yellow. Even the old laptops No one mentioned this in any of the YouTube reviews.
I have manipulated a lot of color settings but the color of the screen is still yellow and warm
Blake_ASUS
Community Legend II
Hi there,
Each panel from different suppliers would have different performance.
faraj_pro
Do all Asus fx516 laptops have the same problem or some may be cooler?
Which suppliers company has a cool color IPS panel for this laptop?
