05-25-2024 01:46 AM
Have a nvidia shield connected directly to the router as well as a synology NAS. The shield is unable to connect to the NAS while both connected with ethernet, however if I change from ethernet to wifi on the shield, I manage to connect. I have read some users experience the same issue but no solution to this.
I have tried other devices as well and narrowed the problem down to the router.
Anyone know what to do?
05-25-2024 09:01 AM
I also have a raspberry pi connected to the router but it neither can`t connect to the NAS.
a month ago
I disconnected both devices from the router, and connected them to a separate hub, and then connected the hub directly to the router. The devices can now communicate. Seems to be firmware problem or something on the router.
a week ago
I have the exact same problem - seems like a software bug indeed. Did you raised a case with Asus?
a week ago
according to your issue, we suggest trying a cross-test using a regular USB cable to check if there is any problem.
Additionally, we recommend resetting your router. You can also connect a computer to the router and perform a ping test between the NAS and the NVIDIA devices to see if they can communicate with each other.
Furthermore, you can also contact NVIDIA customer support to confirm the issue.
