XT8 - on AP mode master for Mesh keeps reverting to factory settings
Jazzym2323
Hello everyone.
I keep experiencing the same problem by setting up three XT8 in mesh.
Everything seems to go fine and works for some time, then the main master unit simply reverts to factory reset.
Setup: mode AP, 2 additional node on LAN, no special settings.
Allready tried:
- hard reset, soft reset, firmware reinstall
- switching units...
Any ideas?
1 ACCEPTED SOLUTION
Accepted Solutions
jzchen
Zen Master II
I just saw this instructions recently, and was surprised at Scenarios 3 and 4, how they are set up.  Also note how to set “Backhaul Priority” on each node.  Not sure it will help stability but maybe you missed something?  (I would have).
https://www.asus.com/us/support/FAQ/1044151/
jzchen
Zen Master II
