WAN 1000
knutsorli
Hi there,
I have a RT-AC68U and im trying to have WAN to distribute 1000 and not 100 as I currently have. Is there anyone that can help me with this?
Supermatico
Hi   knutsorli, it should depend from the ethernet cable connected, have a look on the cable itself which category (CAT) it is
If it is a CAT 5 cable that speed is normal, if you want to have a Gigabit connection you should use at least a CAT 5e cable or above
jzchen
Rising Star II
It should auto negotiate at the highest speed common to both ends.  What are the speeds of the devices connected?
