01-04-2025 06:46 PM
First post here so bear with me if I miss anything. Since purchase, my RT-BE92U has been plagued with the same issues others have posted here. Up until the new firmware version dropped, I was having constant problems with network stability. I am currently running the latest firmware version (3.0.0.6.102_37435) and a lot of the issues seem to have been resolved except for one. Before the firmware update, I was seeing intermittent thermal zone errors in the system log. Since applying the update, I am consistently getting the following errors that appear every 3 seconds exactly:
Jan 4 18:29:52 kernel: read_bpcm_reg_direct_keyhole: Wait for completion failed, devAddr 0x3, offset 24, idx 2
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get RAIL 0 temperature, ret=256
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get temperature, ret=-1
Jan 4 18:29:52 kernel: thermal thermal_zone0: failed to read out thermal zone (-1)
On occasion, the errors coincide with a drastic decrease in wireless network performance. Under normal conditions, when connected to the 6GHz network, my wireless network download speed averages around 1100Mbps. This will drop to a nearly unusable 2-3Mbps. The 2.5GHz and 5GHz networks also see a decrease in speed to around the same 2-3Mbps. Wired clients seem unaffected. Once I perform a hard reset to the router, it seems to correct the speed issue for a while, but the thermal zone errors continue to persist. This seems to happen anywhere from once a week, to every day. Performing a hard reset isn't something I want to nor should have to keep doing to correct the issue every time it happens. Please let me know if there is anything else I can do to stop this from happening. I am getting very close to returning this router and exchanging it for a different brand. Thanks.
Wednesday - last edited Wednesday
The problem is the 6ghz wifi, my iphone 16 pro keeps disconecting randomly. The stability for wifi 7 is bad . I will monitor this issue, rest of devices keep a relatively steady connection (i think:)).
Wednesday
Who has Smart Connect enabled? I am wondering if this is causing a problem. It appears enabled by default and broadcasts a hidden SSID.
Wednesday
deleting my 6ghz profile did nothing for me. Thermal faults persist. Havent done a full reboot after deleting (yet)
Wednesday
Got a reply from ACI-CEO_Feedback@asus.com, hopefully we are starting to get some attention?
Case number: N2502017157-0002
Thursday
I give up, try everything everyone did he. Wifi still reboot randomly. Went back to my RT-AC3100, and not a single disconnect and ms spike. Returning mine tomorrow. very sad, until they fix this or have to go with TP or Netgear.
