09-10-2024 06:37 PM
I just installed an RT-BE88U router and amazingly, got my web server, streaming video server and NAS and all IoT devices working flawlessly.
The only issues seem to be with internal "bells & whistles" type features, such as the internet speed test and firmware updater. They cannot access the internet. Even though the internet status is "connected" and all client PCs have internet. It's baffling. What feature is not enabled that makes this not work? Or are these features not yet implemented in firmware?
Solved! Go to Solution.
a month ago
Since that was updated, I wonder if you can go back to getting the DNS automatically/from the ISP, and it now works properly...
I have never seen the speed test not work. But I have seen the firmware update check fail to connect with update server many times....
09-11-2024 05:48 PM
Found solution to the speedtest not working: had to explicitly assign a DNS server to the router, not "get from ISP" or auto.
a month ago
The Signature version field is there because you have enabled AiProtection. But 2.066 may be old. Please use the Check button to check for updates.
a month ago
Prior to adding the DNS entry, I was unable to check version as well, but now it is working and up to date.
a month ago
Pardon my poor editing skills, but please see attached for my concern.
