08-08-2023 02:34 AM
I have had the RT-AX56U router setup as an AIMesh Node successfully since purchasing it. Recently, perhaps last week, the Node disconnected. I reset the router and stepped through the AIMesh Node setup process a few times but with the same result.
After rebooting both the RT-AX58U the RT-AX56U connects as an AIMesh Node and then disconnects after about 30 minutes or so.
Has anyone else experienced the same?
Log file attached.
08-08-2023 03:30 AM
Hi @marcellus305 ,
based on your issue, may I ask have you set the RT-AX56U as the node and the RT-AX58U as the main router?
Have you make sure that both firmware is at the latest version?
Have you place the AiMesh node between your AiMesh router and the existing dead zone?
If you find the AiMesh node gets bad signal from AiMesh router, please move them closer toward each other.
Also, I did not see the file you attached, seems like you did not attached successfully.
We kindly request you to report the problem through feedback. Please follow the steps below to report the issue through the Web management interface:
Additionally, please provide the product serial number, the time you sent the feedback report, the email used for the feedback report, and the time when the issue occurred via private message.
08-08-2023 05:09 AM
08-08-2023 08:22 PM
Hi @marcellus305 ,
based on the issue, may I ask whether you're using wired or wireless connection?
Have you try to cross test with other connection?
Also, I did not see the log file only the screenshot can be seen.
If you have report the feedbak log, please provide the product serial number, the time you sent the feedback report, the email used for the feedback report, and the time when the issue occurred via private message.
Please make sure if you are connected to the Internet. If you are not, you might not be able to submit your feedback.
08-09-2023 01:59 AM
Thanks.
Have messaged privately and the report submission has been completed.
