RT-AX55 IGMP filter
Asusme1
I am using Firmware Version: 3.0.0.4.386_52332 on my WIFI rtax55 router and would like to know if IGMP can be turned off or filtered on ports? IGMP uses IP 224.0.0.x.
Aureliannn_ASUS
Hi @Asusme1 ,
To disable IGMP, you can turn off the IGMP Snooping feature. Please follow the path below to configure it:
Go to [Wireless] > [Professional Settings] > Enable IGMP Snooping > Disable.
We greatly appreciate your understanding and cooperation.
HI
Thanks. But I already have that disabled and still see IGMP.
Asusme1
Is this a known bug ?
