rt-ax55 does not show log into router
Asusme1
Running version 3.0.0.4.386 52332 the system log does not show when the RT-ax55 is access by an administrator in the system log.  I have included a sample of the system log to identify when the router is accessed?
Feb 14 13:14:57 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=198.251.52.3 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=37166 DF PROTO=ICMP TYPE=8 CODE=0 ID=42400 SEQ=1
Feb 14 13:14:58 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=14080 DF PROTO=TCP SPT=37044 DPT=80 SEQ=1071332893 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650D92820000000001030307)
Feb 14 13:14:59 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=46242 DF PROTO=TCP SPT=57206 DPT=80 SEQ=1762114619 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650D93820000000001030307)
Feb 14 13:15:06 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=14081 DF PROTO=TCP SPT=37044 DPT=80 SEQ=1071332893 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650DB2820000000001030307)
Feb 14 13:15:07 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=46243 DF PROTO=TCP SPT=57206 DPT=80 SEQ=1762114619 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650DB3820000000001030307)
Feb 14 13:15:12 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=198.251.52.3 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=38341 DF PROTO=ICMP TYPE=8 CODE=0 ID=42512 SEQ=1
Feb 14 13:15:21 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=44.238.175.141 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=22545 DF PROTO=TCP SPT=47606 DPT=443 SEQ=2705194608 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AE97DF0C60000000001030307)
Feb 14 13:15:21 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=1.1.1.1 LEN=62 TOS=0x00 PREC=0x00 TTL=63 ID=33585 DF PROTO=UDP SPT=53800 DPT=53 LEN=42
Feb 14 13:15:21 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=49785 DF PROTO=TCP SPT=41988 DPT=80 SEQ=3030764400 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD2334FDD0000000001030307)
Feb 14 13:15:21 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=58484 DF PROTO=TCP SPT=42004 DPT=80 SEQ=1391017410 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD23350D60000000001030307)
Feb 14 13:15:22 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=49786 DF PROTO=TCP SPT=41988 DPT=80 SEQ=3030764400 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD23353D60000000001030307)
Feb 14 13:15:22 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=58485 DF PROTO=TCP SPT=42004 DPT=80 SEQ=1391017410 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD23354D60000000001030307)
Feb 14 13:15:23 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=14082 DF PROTO=TCP SPT=37044 DPT=80 SEQ=1071332893 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650DF1820000000001030307)
Feb 14 13:15:23 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=46244 DF PROTO=TCP SPT=57206 DPT=80 SEQ=1762114619 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650DF2820000000001030307)
Feb 14 13:15:24 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=49787 DF PROTO=TCP SPT=41988 DPT=80 SEQ=3030764400 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD2335BBA0000000001030307)
Feb 14 13:15:24 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=58486 DF PROTO=TCP SPT=42004 DPT=80 SEQ=1391017410 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD2335CB60000000001030307)
Feb 14 13:15:27 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=192.168.10.1 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=56500 DF PROTO=ICMP TYPE=8 CODE=0 ID=42542 SEQ=1
Feb 14 13:15:28 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=49788 DF PROTO=TCP SPT=41988 DPT=80 SEQ=3030764400 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD2336C360000000001030307)
Feb 14 13:15:28 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=58487 DF PROTO=TCP SPT=42004 DPT=80 SEQ=1391017410 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD2336D360000000001030307)
Feb 14 13:15:36 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=49789 DF PROTO=TCP SPT=41988 DPT=80 SEQ=3030764400 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD2338C360000000001030307)
Feb 14 13:15:37 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=58488 DF PROTO=TCP SPT=42004 DPT=80 SEQ=1391017410 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD2338D360000000001030307)
Feb 14 13:15:42 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=192.168.10.1 LEN=84 TOS=0x00 PREC=0x00 TTL=63 ID=60082 DF PROTO=ICMP TYPE=8 CODE=0 ID=42557 SEQ=1
Feb 14 13:15:53 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=49790 DF PROTO=TCP SPT=41988 DPT=80 SEQ=3030764400 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD233CB360000000001030307)
Feb 14 13:15:53 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=58489 DF PROTO=TCP SPT=42004 DPT=80 SEQ=1391017410 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD233CC360000000001030307)
Feb 14 13:15:54 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=52.27.37.162 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=47586 DF PROTO=TCP SPT=52574 DPT=443 SEQ=3168339783 ACK=0 WINDOW=65340 RES=0x00 SYN URGP=0 OPT (020405AC0402080AE09057540000000001030307)
Feb 14 13:15:54 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=31062 DF PROTO=TCP SPT=58860 DPT=80 SEQ=2397057992 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650E6DFB0000000001030307)
Feb 14 13:15:54 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=1.1.1.1 LEN=72 TOS=0x00 PREC=0x00 TTL=63 ID=43632 DF PROTO=UDP SPT=54376 DPT=53 LEN=52
Feb 14 13:15:55 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=17558 DF PROTO=TCP SPT=58872 DPT=80 SEQ=2703499439 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650E6EF50000000001030307)
Feb 14 13:15:55 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=1.1.1.1 LEN=72 TOS=0x00 PREC=0x00 TTL=63 ID=55356 DF PROTO=UDP SPT=35023 DPT=53 LEN=52
Feb 14 13:15:55 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=14083 DF PROTO=TCP SPT=37044 DPT=80 SEQ=1071332893 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650E71860000000001030307)
Feb 14 13:15:55 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=46245 DF PROTO=TCP SPT=57206 DPT=80 SEQ=1762114619 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650E71860000000001030307)
Feb 14 13:15:55 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=31063 DF PROTO=TCP SPT=58860 DPT=80 SEQ=2397057992 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650E72060000000001030307)
Feb 14 13:15:56 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=17559 DF PROTO=TCP SPT=58872 DPT=80 SEQ=2703499439 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650E72E20000000001030307)
Feb 14 13:15:57 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:b0:83:fe:7f:14:b7:08:00 src=192.168.200.177 DST=162.159.200.123 LEN=76 TOS=0x18 PREC=0xA0 TTL=63 ID=40860 DF PROTO=UDP SPT=123 DPT=123 LEN=56
Feb 14 13:15:58 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=31064 DF PROTO=TCP SPT=58860 DPT=80 SEQ=2397057992 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650E79E60000000001030307)
Feb 14 13:15:58 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=17560 DF PROTO=TCP SPT=58872 DPT=80 SEQ=2703499439 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650E7AC60000000001030307)
Feb 14 13:16:02 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=31065 DF PROTO=TCP SPT=58860 DPT=80 SEQ=2397057992 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650E8A820000000001030307)
Feb 14 13:16:02 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=17561 DF PROTO=TCP SPT=58872 DPT=80 SEQ=2703499439 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650E8A820000000001030307)
Feb 14 13:16:02 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=23.34.209.206 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=32102 DF PROTO=TCP SPT=33334 DPT=443 SEQ=1910507295 ACK=0 WINDOW=65340 RES=0x00 SYN URGP=0 OPT (020405AC0402080A5D60C4CD0000000001030307)
Feb 14 13:16:04 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:b0:83:fe:7f:14:b7:08:00 src=192.168.200.177 DST=23.205.255.42 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=30880 DF PROTO=TCP SPT=48286 DPT=443 SEQ=1582495081 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AB31B31D70000000001030307)
Feb 14 13:16:04 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:b0:83:fe:7f:14:b7:08:00 src=192.168.200.177 DST=23.205.255.42 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=53911 DF PROTO=TCP SPT=48292 DPT=443 SEQ=747360857 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AB31B32D10000000001030307)
Feb 14 13:16:04 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:b0:83:fe:7f:14:b7:08:00 src=192.168.200.177 DST=18.67.17.115 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=49255 DF PROTO=TCP SPT=48242 DPT=443 SEQ=11219331 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080ACBDC1F2E0000000001030307)
Feb 14 13:16:05 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:b0:83:fe:7f:14:b7:08:00 src=192.168.200.177 DST=23.205.255.42 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=30881 DF PROTO=TCP SPT=48286 DPT=443 SEQ=1582495081 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405AC0402080AB31B35CE0000000001030307)
Feb 14 13:16:09 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:b0:83:fe:7f:14:b7:08:00 src=192.168.200.177 DST=151.101.125.188 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=4002 DF PROTO=TCP SPT=53112 DPT=443 SEQ=8901914 ACK=0 WINDOW=65340 RES=0x00 SYN URGP=0 OPT (020405AC0402080A89B756970000000001030307)
Feb 14 13:16:10 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=17562 DF PROTO=TCP SPT=58872 DPT=80 SEQ=2703499439 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650EAA820000000001030307)
Feb 14 13:16:10 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=31066 DF PROTO=TCP SPT=58860 DPT=80 SEQ=2397057992 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650EAA820000000001030307)
Feb 14 13:16:22 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:b0:83:fe:7f:14:b7:08:00 src=192.168.200.177 DST=74.125.0.41 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=3860 DF PROTO=TCP SPT=38744 DPT=443 SEQ=1655418658 ACK=0 WINDOW=65340 RES=0x00 SYN URGP=0 OPT (020405AC0402080AA1C0AF680000000001030307)
Feb 14 13:16:26 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=49791 DF PROTO=TCP SPT=41988 DPT=80 SEQ=3030764400 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD2344E360000000001030307)
Feb 14 13:16:26 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=31067 DF PROTO=TCP SPT=58860 DPT=80 SEQ=2397057992 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650EE9820000000001030307)
Feb 14 13:16:26 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=172.64.149.23 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=58490 DF PROTO=TCP SPT=42004 DPT=80 SEQ=1391017410 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AD2344E360000000001030307)
Feb 14 13:16:26 kernel: ACCEPT IN=br0 OUT=eth0 MAC=e8:9c:25:af:2f:50:08:22:12:23:13:cc:08:00 src=192.168.200.112 DST=18.154.117.5 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=17563 DF PROTO=TCP SPT=58872 DPT=80 SEQ=2703499439 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A650EE9820000000001030307)
Aureliannn_ASUS
Hi @Asusme1 ,
Thank you for your inquiry.
Regarding your question about router login logs, we would like to clarify the following:
  • Successful login: If you can successfully log in to the router management interface, it means that your login was successful. Generally, the router will not specifically record the login time for each successful login.
  • Failed login attempts: Only failed login attempts (e.g., incorrect password) will be recorded in the logs.
Therefore, if you can successfully log in to the router and have not encountered any login issues, detailed login time records will usually not be displayed in the logs.
Asusme1
I am interested in knowing all logins to the router successful or non successful. The system log shows neither. If a a log in failure occurs you will not see it in the log. Look at the included system log .
Asusme1
Hers is an example of a log from another router that shows successful log in and out of the router.
Fri, 07 Mar 2025 12:45:50 User login from b8:9d:2a:A5:27:80(192.168.100.3),Authentication fail
Fri, 07 Mar 2025 12:46:26 User login from b8:9d:2a:A5:27:80(192.168.100.3),Authentication success.
