- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-01-2024 06:37 PM
The setup is an AX86U Pro and two AX3000’s in a AiMesh System. After completing the setup, I wonder if the three networks and passwords should be identical or three individuals?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-02-2024 12:20 AM
After completed the AiMesh setup. Wifi SSID and password of the AiMesh nodes will use the host AiMesh router SSID and password. All clients do not need to do any Wifi configurations setup as they use identical login.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-02-2024 12:20 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-02-2024 02:00 AM
For your AiMesh setup with the AX86U Pro and two AX3000 routers, it's best to use the same network name (SSID) and password across all routers. This allows for seamless roaming, where your devices automatically connect to the router with the best signal. It also simplifies network management, as everything runs under one unified network. However, if you want more control over which devices connect to which router, you can set different SSIDs, but for most users, the same SSID across all routers is the optimal choice.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-02-2024 12:40 PM
Thanks for both answers. I appreciate your interest and time taken.
