Asus G751JY wifi antenna replacements.
k1aska
Hello all, I'm looking for a replacement auxillary wifi antenna on an Asus g751jy laptop and am having a hard time finding a replacement or compatible one. I replaced the battery on it and noticed the wifi chip was damaged. After examining it under a microscope I could see the auxillary antenna connector was damaged from both antenna and chip side. Already replaced the chip but does any one know the specifications on a replacement auxillary antenna or where I can find one?
travishead
To replace the auxiliary Wi-Fi antenna for your Asus G751JY laptop, you'll need to find a compatible antenna with the correct connectors and specifications. Most likely, you'll need an MHF4 connector antenna, which is common in many laptops. The antenna's size typically ranges from 10 cm to 20 cm in length, depending on the model.
