Mesh wifi
Majonez123
If there is mesh Wi-Fi and you put up the first tower and connect it to the Internet provider's modem, do you have to turn off Wi-Fi in the modem so that it does not interfere with the mesh coverage?
jzchen
Zen Master II
Most likely yes you want to turn off WiFi on a non ASUS router meaning it’s not AiMesh compatible.
Preferably you’d set the ISP modem router combo to Bridge mode.  But there are times, or if bridge mode is not available, to set it to IP Passthrough.
