Manage RT-AC88U router without an Internet connection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-09-2024 09:33 AM
We have a RT-AC88U (and RT-AC68U on AIMesh) connected to the Frontier FIOS service. The AC88U is running 3.0.0.4.386_48263
Whenever I want to administer the router (using 192.168.0.1, or the router.asus.com address which replaces that IP), there's no response or a plain white page - unless the router has a working Internet connection.
Once the WAN is working, the router's admin pages all come up just fine.
This seems like a paradox, as I will never be able to administer the router (to fix a WAN configuration issue) when the router cannot contact the Internet.
Is there a setting I can change, which will allow me to admin the router from the LAN - when the WAN's not there?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-11-2024 08:33 AM
It happened again this AM. The router lost it's primary WAN connection to Frontier FIOS, and I wanted to switch it over to our secondary WAN - a Wi-Fi modem connected to port 1.
BUT I COULDN'T LOG IN to the router to do this, because it had no WAN connection and therefore just gave me a blank white page (no source html).
This paradox cannot possibly represent correct behavior. Am I right?
Besides contacting Asus directly (I tried), and this community forum, is there any other resource out there? Maybe a social media group or something?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-11-2024 08:43 AM
Should I just try the Asuswrt-Merlin firmware instead?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-12-2024 09:14 AM
@jzchenVery good stuff, thanks!
I have not enabled a https login, and - until your response - did not even know such a thing was possible.
UPDATE: Actually I guess it's not: I get a plain vanilla "Unable to connect" when I try those links today, not even a cert warning. This router apparently don't play that. 😉
Point taken on the router's age, I'm hosed if the root cause of all this is an impending hardware failure and not a firmware bug. I will need to shop for a newer model, but one with AiMesh support for the wired RT-AC88U in our tenant's ADU.
I presume the newer models will let someone access the admin pages from the LAN - over Wi-Fi - if the WAN is not available.
Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-12-2024 09:25 AM
It seemed to show a redirect in one of your posts. I do believe ASUS at one point changed from router.asus.com to "asusrouter.com" (without the quotes, so definitely give that a shot if your router drops WAN). Frontier fiber is pretty darn stable from personal experience...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-12-2024 09:46 AM
Yes, it redirects from http://192.168.0.1/ to http://router.asus.com/ whenever I try to connect via IP.
If there's no WAN available, it returns a big blank nothing.
