03-21-2024 10:20 AM
Recently started getting some errors and was wondering if anyone had some info on them. Are they significant, are they indicators of a failing router, is there something I can fix, etc. These all seem to happen regularly recently and I do not recall them appearing over the several years I've been running my RT-AC88U. Currently running stock firmware 3.0.0.4.386_48263.
First (no USB disks are attached so I assume this is the internal file system):
Mar 20 23:00:32 disk_monitor: Got SIGALRM...
Second (I think this might have something to do with the wireless connection to my spare RT-AC3100 in the living room I have set to access port mode for my TV and streamers downstairs and seems to be working fine. But I am not sure about that.)
Mar 21 01:00:37 kernel: EMF_ERROR: Interface wds1.1.502 doesn't exist
Mar 21 01:00:37 kernel: EMF_ERROR: Interface wds1.1 doesn't exist
Third (Get this over and over in the logs. Not a lot but they started showing up maybe 3 months ago):
Mar 15 07:31:27 kernel: rtk_port_linkStatus_get() fail, err: 14
Mar 15 07:31:27 rtl_fail: rtkswitch fail access, restart.
Mar 15 07:31:29 kernel: rtl8365mbrtl8365mb initialized(0)(retry:0)
Mar 15 07:31:30 kernel: rtk port_phyEnableAll ok
Mar 15 07:31:30 kernel: txDelay_user: 1
Mar 15 07:31:30 kernel: # txDelay - TX delay value, 1 for delay 2ns and 0 for no-delay
Mar 15 07:31:30 kernel: EXT_PORT:16 new txDelay: 1, rxDelay: 4
Mar 15 07:31:30 kernel: current EXT_PORT:16 txDelay: 1, rxDelay: 4
Mar 15 07:31:30 kernel: rxDelay_user: 4
Mar 15 07:31:30 kernel: # rxDelay - RX delay value, 0~7 for delay setupEXT_PORT:16 new txDelay: 1, rxDelay: 4
I would say the router may be acting a bit weird lately but I do have it set to reboot every Sunday at 1AM.
No, I have not sent a log to Asus yet. Trying to educate myself via the community first.
Thanks!
