Firmware: Signature Version: 2.376 2023/10/17 - Filling System Log with errors
Rooke
Router: RT-AC66U B1 (AC1750); Firmware Version: 3.0.0.4.51665 ;
On Tuesday, 2023/10/17, I noticed the entire System Log filled with the same repeating errors, all starting with error: "kernel: dcd/22609: potentially unexpected fatal signal 6." The only difference between the errors is the dcd number.
I checked the Administration menu, Firmware Upgrade tab, and found that the Firmware Signature Version had been updated to "2.376 2023/10/17 09:04" which was a couple of hours before I checked the logs.
After seeing that, I unplugged the Router for a few minutes and plugged it in again and let it boot up.
The errors went away for about an hour then came back. Subsequent (4) power off/on resulted in the same situation.
The errors do not seem to be affecting the router's performance, but the problem needs to be addressed by Asus. Attached is a snippet of the errors.
73 REPLIES 73
I think I found a workaround.
connect with ssh to your router (example: ssh user@192.168.0.1  )
r@RT-AC66U_B1-AED0:/tmp# cd /tmp
 r@RT-AC66U_B1-AED0:/tmp# dcd
[parse_cmd(389)] cert file "./ntdasus2014.cert" doesn't exist!
 r@RT-AC66U_B1-AED0:/tmp# touch ntdasus2014.cert
 r@RT-AC66U_B1-AED0:/tmp# nohup dcd &
r@RT-AC66U_B1-AED0:/tmp# exit
dcd is started and not killed anymore each two minutes.
Thanks! It works, no errors.
EDIT:
No errors: kernel: dcd/6131: potentially unexpected fatal signal 6
but now every 30 minutes error:
kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
_____________________________________________________________________________________________________________________________
The second method is the new Merlin beta firmware
For my AC68U changelog:
Asuswrt-Merlin Changelog
386.12_2 (xx-xxx-2023)
- UPDATED: openssl to 1.1.1w.
- UPDATED: curl to 8.4.0.
- FIXED: WPS not working on SDK6/SDK7 devices (affecting
RT-AC68U and RT-AC88U/3100/5300)
- FIXED: dcd constantly crashing (updated Trend Micro
components)
EDIT:
I`m tested beta Merlin`s FW, it`s works fine, no errors
Do you have a link to 386.12_2 (xx-xxx-2023)? I wasn't able to find it on Source Forge, OneDrive, or GitHub. Clearly looking in the wrong place.
ASUSWRT-MERLIN
go to > Pre-beta test builds (occasionally available, hosted on Onedrive)
Adam_M
New Firmware 386.12_2 from Merlin fix all problems in my AC68U
changelog:
386.12_2 (12-Nov-2023)
- UPDATED: openvpn to 2.6.7.
- FIXED: WPS not working on SDK6/SDK7 devices (affecting RT-AC68U and RT-AC88U/3100/5300)
- FIXED: dcd constantly crashing (updated Trend Micro components)
