2 weeks ago
Gday
With the EBM68, can the different SSID created be on a separate channel? or do they all share the same channel?
Solved! Go to Solution.
Wednesday
You can assign different SSIDs to specific channels within the same frequency band. This means you can set up, for example, SSID1 on the 2.4 GHz band using channel 2 and SSID2 on the same 2.4 GHz band using channel 10.
For the 2.4 GHz band, you can set up multiple SSIDs. Assign SSID1 to channel 2 and SSID2 to channel 10 by selecting the desired channel from the control channel dropdown menu.
Wednesday
this is amazing
ill get a pair then. once they're on special again
