09-12-2023 05:43 AM
Hi Asus Experts and fellow community members!
Does ROG Rapture GT-AX11000 Pro AiMesh work with Asus ZenWifi XT8 as the child nodes? The reason I am thinking of such a set-up is because I wish to utilize the 10GbE WAN port on the AX10000 Pro for my incoming WAN connection.
Therefore, does the XT8 mesh well with the AX11000 Pro? Please advise! Thanks in advance!
Solved! Go to Solution.
09-28-2023 07:01 AM
Any ASUS AiMesh Router meshes with any other AiMesh product. If you may ever wire the LAN side you may consider something with a 2nd 10 G port, (both WAN and LAN support 10 Gigs).
I’m afraid I can’t tell you from personal experience whether they work well together, but I have seen huge networks on the ROG Networking forum pages (@david_mckee1 has a GT-AXE16000 with 4 XT8 nodes, among others): https://rog-forum.asus.com/t5/gaming-routers/trivial-issue-with-gt-axe16000-running-3-0-0-4-388-2223...
09-28-2023 07:01 AM
09-30-2023 10:57 AM
Thank you for your input, jzchen! It is much appreciated. 🙏
