02-14-2024 11:25 PM
Hii I'm Darshan Hiranandani here. Experiencing connectivity issues with my ASUS router. How do I fix it?
02-15-2024 11:09 PM
Hi @darshanhira ,
based on your issue, whether you could provide the router model?
Have you make sure tha the router firmware is at the latest version?
May I ask did you use the wired connect? Make sure that all the cable is well connect.
Have you try to cross test with other ethernet cable?
If you're using Wi-Fi, try changing the wireless channel on your router to reduce interference from other nearby networks.
It is suggest that you can try hard reset your router.
You can refer to the following link:
[Wireless Router] ASUS router Hard Factory Reset - Method 1 | Official Support | ASUS Global
