Darshan Hiranandani : Can I Set Up Two Separate 2.4GHz Networks?
darshanhira
Hi, Everyone, I am Darshan Hirnandani, currently using an ASUS AiMesh system with an RT-AC5300 as the main router, and RT-AC88U and RT-AC68U as AiMesh nodes, all connected via Ethernet. I'm interested in setting up two independent 2.4GHz networks. Is it possible to achieve this with my current setup, or would I need to add another router? Any advice or guidance would be greatly appreciated.
Regards
Darshan Hiranandani
jzchen
Zen Master I
I believe you can accomplish this by switching the node(s) to Access Point mode.  Each one can then be set with a separate SSID.
An alternative would be to set up a Guest Network:
https://www.asus.com/us/support/faq/1042732/
