10-25-2025 03:21 AM - edited 10-25-2025 03:28 AM
I am using multiplicity KVM from Stardock software. I tried to replace my Asus AX88U non-pro model router with the Asus BE88U router and the KVM wont connect with the BE88U but will work with the AX88U.
I also checked the firewall on the target machine and the software is in the list, the app is set to secondary, and KVM is not disabled.
Other things I have tried so far:
Factory Resetting the router
Removing the switch and connection both PCs directly to the router
Enabling the DMZ and testing both IP addresses
Port forwaring the Multiplicity documented ports
Double checked all firewall settings in Windows Defender Firewall to make sure no specific settings were enabled for the primary PC to connect
Completely disabling the firewall on the router
10-26-2025 02:57 AM
Well, you probably found a new CVE for the AX88U....
10-26-2025 10:05 PM
well thats neat. If this qualifies for the bug bounty program i do accept 5090s as a reward
11-08-2025 09:21 AM
Try turning off the 5GHz Control Channel.
a month ago
I appreciate the input. we discovered the probleml
