AXE6600 ET8 6Ghz issue
Cdamania10
Hello All, I am facing a weird issue. I have 4 Asus ET8 setup as a route and yhe rest nodes. Back haul via ethernet connected to a gig switch. It use to work perfectly where all the bands were showing. 2Ghz, 5Ghz and 6Ghz and I had my phone connected to the 6Ghz and showing 6E and if I would move around the house it would transfer the phone to different nodes. Recently I started noticing that even though the wifi 6Ghz is enabled only the ET8 that assets as the main router works with 6Ghz the nodes don't work for 6Ghz it will not display it but setting shows that it's enabled and on.  When I go close to the main router ET8 it connects to 6Ghz instantly. Not sure what is happening and my suspension is something was messed up.after a firmware update came thru. Any assistance would be appreciated. I did a factory reset and still the same.
77 REPLIES 77
Unbelievable. What is the reason to RMA your units. The issue is happening to every single ET8. They should be able.to replicate the issue by installing the firmware that they provided in a more than 2 node setup.
One would think. But I have a feeling they'll inconvenience me and say everything is ok. Which is sad. Because it's really easy to replicate the issue.
Exactly. An easy way out and basically say we made our money in this model. Move on to next one.
Not if there's a lawsuit.
Exactly. I may have to go back to my eero pro 6e in the meantime while this is resolved. It's terrible. I pay for 1g internet and can even fully utilize the speeds.
