Asus ZenWiFi Pro ET12 features
jve344
I'm trying to find out whether a #Zenwifi Pro ET12 has a ventilator on board as well whether it can be ran without any lights active? Reason to ask is because the  equipment would have to be put in a quite room with people and low light where both sound and light distract from the w
Aureliannn_ASUS
Hi @jve344 ,
based on your question, the ZenWiFi Pro ET12 is designed with LED indicator lights on the top for users to easily understand the router's status by color. It does not produce significant operating noise, but sound perception and light preferences can vary from person to person. I would recommend visiting a retailer to physically inspect the device and ensure it meets your requirements. You can refer to the link below for specifications and design details of this device. Thank you.
ASUS ZenWiFi Pro ET12|Whole Home Mesh WiFi System|ASUS Global
