12-31-2024 03:58 PM
I have an ASUS RT-BE92u with new firmware.
My iPad has been disassociated from WiFi many times (lots of information in the router log).
I tried using fix from this forum about disabling OFDMA/802.11ax MU-MIMO for all frequency but problem still exists. Does ASUS have any problems with Apple? Any settings to adjust?
01-02-2025 03:12 AM
I prepared separatly SSID for 5 GHz and 6GHz. In BE asus router I dont see Smart connect option in the setting. Default when you to prepare new SSID all frequencies was added. On the "old" ASUS GT-AX6000 I was Smart connect options in wireless setings.
yes I re-enable OFDMA MU-MIMO and iPAD connection works great.
01-02-2025 11:41 PM
Hi @rmb4 ,
To more accurately identify the problem, we would like you to confirm the following:
01-03-2025 10:18 AM
1. Yes I have samsung phones and pc but I was problem only with iPAD
2. I haven’t this options in Wireless-general tab and professional.
3. I have last version software on router- please to read my post
4. I also reset the router to factory settings
01-05-2025 05:45 PM
Hi @rmb4 ,
Thank you for your reply.
To better understand the AirDrop connectivity issue you're experiencing, we would like to further confirm:
You can submit a feedback form Web GUI (http://www.asusrouter.com).
1. Connect your device to your router and log in to Web GUI(http://www.asusrouter.com)
2. Find “Administration,” and tap “Feedback”
3. Fill in your region, email (required field), ASUS Service No./Case No.(not required),Select the feedback problem and description.You can also write down comments/suggestions. More details might help us to analyze the issue you have encountered in a faster and more efficient way.
4. Read the agreement and click “I agree.”
5. Tap “Send” to submit your feedback.
Then provide the product serial number, the time of submitting the issue report, the email used for filling out the issue report, and the time when the issue occurred via private message.
