2 weeks ago - last edited 2 weeks ago
5g wifi is not visible. if the channel is even below 100 (auto)
5g wifi is visible only when manually set below 100 channels
from time to time such a wifi also appears little by little. when i put the channel manually i think it is related to 5g. if you write a password, it does not enter the 5g password. but wifi is also visible
2 weeks ago
guest network
The wifi scheduler does not turn off on the guest network at the set time
2 weeks ago
I checked on 3 phones
The problem is the same with 2 smart TVs in 1 notebook.
2 weeks ago
That long SSID is indicative of MLO turned on. Not sure why 5 GHz does not show, but you may want to create a Legacy/IoT SSID and password for non-WiFi 7 devices, and see if that 5 GHz shows.
