TUF Gaming B550M-Plus Wifi II - Wifi device could not be found/installed
EmmaEntenfuss
Hello,
we bought the TUF B-550M-Plus Wifi II motherboard to replace an exsiting B450-F Gaming II motherboard. The other components are an AMD Ryzen 5 3600, 32GB 3200MHz RAM (4x 8GB), an ASUS Radeon RX 6650XT. On the old mb, we had several issuesover the last 2 years with an external Intel Wifi Chip, we built onto the M.2 e-Key slot.
First try was to upgrade from Window 10 pro to Windows 11, but it didn't fixed the Wifi issues and some overheating problems from time to time. So we bought the new motherboard.
Windows and several Steam games run fine with the new setup, but we didn't got the onboard wifi to work. We tried the official fix for this here: https://www.asus.com/de/support/faq/1045135/ and some other tutorials from YT and other hardware related websites (https://www.reddit.com/r/ASUS/comments/qpjike/asus_tuf_gaming_b550plus_wifi_wifi_not_working/). Nothing works.
The wifi device in the Windows device manager isn't detected as MediaTek wifi controller, but as unknown network controller. There are no wifi settings shown in the windows/network connections. The Bluetooth controller isn't detected at all, but is shown in the windows desktop bar. lol
We tried to deinstall/delete the devices in the device manager and update it, but after 1 second, it founds the unknown controller again.
We also tried to install it via the Armory Crate software. The software detects, that are no software for these controllers/devices are installed. But when I try to download and install it via Armory Crate, it stops the installation process at around 50%, a windows pops up with "installation successfull" but it didn't install the software.
We also tried to install the software for wifi and bluetooth manual, with the latest downloads from the ASUS website. Again, after starting the installtion files (no matter the setup.exe or the .bat) and short after 1 second, it stops. You see a black window for the blink of an eye but then, it disappears and there is no installation.
It seems, that the whole wifi/bluetooth chip on the board isn't working.
Any ideas from the support?
thanks in advance
EmmaEntenfuss
screenshot: missing wifi oiptions in the Windows network settings
EmmaEntenfuss
video: manual installation (didn't work)
Hello @EmmaEntenfuss
Thank you for reaching out to us.
Could you please confirm if you switched from the ROG STRIX B450-F GAMING II to the TUF GAMING B550M-PLUS WIFI II due to Wi-Fi issues and occasional overheating, and if the problem still persists?
Aside from the MB change, have there been any other changes to the specifications you provided?
If not, we recommend restoring or resetting the system, ensuring that the BIOS is updated to version 3607, and checking again after clearing CMOS.
Kindly consider removing the current SSD and HDD, cross-testing with other system drives, or performing a fresh installation on a new system drive.
If the issue persists, could you please record and provide the relevant logs for further verification?
For instructions on logging, please refer to "Q5: What is App Diagnostics? (New Feature)" and ensure that the "Record Log" option is selected before replicating the issue, such as updating Wi-Fi to 50% and experiencing issues with Wi-Fi recognition after rebooting.
And kindly record a video simultaneously and provide it to us, allowing us to better correlate the log with the actual scenario.
After recording the log, please upload it to the cloud, approve access, and PM me the link.
Meanwhile, please share the requested information below as well:
- the images of BIOS main page and all the manually adjusting items in BIOS
- the serial numbers of your motherboard and GPU via pm
- the brand and model name of the RAM (part number and installed slots as well), SSD/HDD, and PSU currently installed
- are there any extensions or adapters used to connect any devices, such as GPU or SSD?
- the OS version and OS build
- Armoury Crate version and a screen shot of the Armoury Crate Update Center
